~NEW Comp Turbo Standard T4 turbos w/ 79mm Turbine Wheel
We just got in our order for the Brand New Comp Turbos. These are their CT43's with the large 79mm turbine housing, however now available with options to make these the most affordable larger turbine wheel'd standard T4s on the Market.
We received in what I like to call the "base model" and then a hopped up version.
Base Model:
CT43
360 Journal Bearing
Cast 76mm Compressor Wheel
79mm Turbine Wheel
.96 a/r open housing w/ 3" exit
Satin Compressor Cover
Oil Only
These units we will sell at $1249 SHIPPED and I have one in stock!
Upgraded Model:
CT43
360 Journal Bearing
BILLET 76mm Compressor Wheel
79mm Turbine Wheel
Anti-Surge Compressor Cover
Polished Compressor Cover
Oil Only
This unit with the up-grades we will sell at $1529 SHIPPED and I have one in stock!
We can get these built in any form to suit your needs including the following options, just PM me for a quote!
Compressor Cover
-Satin or Polished
-Anti-surge or non
Bearing
-360 Journal
-Triplex Triple Ball Bearing
Oiling
-Oil Only
-Oil + Water
-Oil-less (water only)
Compressor wheel
-Cast
-Billet
Turbine Housing
-many options from .81 to 1.32 a/r ratios
-3", 3.5" or 4" V-band discharge
Check them out on our website for pricing with options built to your liking: http://www.shop.huronspeedproducts.c...ger-comp43.htm
And finally a comparison next to the other top performing standard T4's!
In both pictures, from left to right: Precision 7675, Turbonetics 7875, Comp 7679
Base Model:
CT43
360 Journal Bearing
79mm Turbine Wheel
Oil Only
Upgraded Model:
CT43
360 Journal Bearing
79mm Turbine Wheel
Oil Only
Compressor Cover
-Satin or Polished
-Anti-surge or non
Bearing
-360 Journal
Oiling
-Oil Only
-Oil + Water
Compressor wheel
-Cast
-Billet
Turbine Housing
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
I don't mean to mess up your thread but Im wondering if you personally have tested these turbos on an ls engine.
Reason I ask, my self and a few others have had horrible back pressure issues especially with the billet comp wheel and 79 turbine.
they switched me out to the cast comp wheel and it helped a lot but it was still done at 5200rpm. Since comp sent me a ct5 with a ct43 cover, 88mm comp 94/88 turbine and that thing rocks.
This was 2 years ago so maybe they changed some thing. Just an fyi if you haven't tested yet, I run a 370 ci.
The technology in these is much better than a box stock S475. Both will react differently on different set-ups, but for an LS motor up to 370 CI, I would run one of these all day long, and they package MUCH nicer than a BW
__________________
__________________
That is the beauty, these drop in to most turbo setups with the T4 flange and 3" v-band exit. They package so nicely and pack a huge punch as well
__________________
Let me know what exact specs you are lookin for on dimensions and I can take them for you. It is a 4" inlet and 3" outlet on the compressor with a t4 flange and a 3" discharge on the turbine. Physical size is near identical to the turbonetics t series and the precision pt7675, however anything specific just let me know and I can take that measurement for you!
Would it be a worthwhile swap for me going from a Turbonetics 7875 on my LQ4? Figured you might have a decent idea since you sell a lot of all three turbos listed. My 7875 drops off pretty good after 5700 rpm. I am sure a cam change would help me a bit as well though.
Yes, direct replacement to that turbo! Hotside is the same. If you are running the t series housing the cold side will also be near identical other than the 3" outlet opposed the 2.5". If you have the tc housing this one will be a touch bigger on the compressor siZe but not much!
