what cam to go with.......
i know a million people ask this question but i kinda need to get some good ideas from some of you one here....
i was going to go with a comp cam but now i just found out about this tsp cam..."magic stick".....which, is better for power???...my car has full bolt-ons plus a 4.10 and it's an m6..i kinda wanna keep my stock 10 bolt around for a while....what should i go with plus i'll be using a drag radial
i drive the car kind of everyday so driveability needs to be pretty good
ok....read up.....
BIG POWER + STOCK REAR + DRAG RADIAL = BROKEN REAREND
If you wanna go big...
you gota put in a 12 bolt or a 9 inch
and you better make it 4.10's or 4.30's...you could go with 4.56's but daily driving would be a bitch...
I am putting the magic stick 1 in my car motor should be in the car in about two week if you want email me and i will give you all the details. Also i would watch what you do with stock rear end if you keep street tires you will probably be ok. Also I really recomend 231/237 it just wasn't enough for me.
Originally Posted by jrp
go with the brand new super high tech PRJ v.x8 gigantor cam.
I'm still waiting on my Texas Two-Step from Harlan....
LS1TECH Sponsor
Originally Posted by BLASTER
In my opinion this doesn't go togther well with anything over a 230. Am I wrong? I know it's all in the tune I but I think he should stick with something in the 224-230 ish range. Maybe the TSP 231. Bu tI wouldn't go any bigger than that.
Forget the drag radials on a stock 10 bolt. You won't be driving it everyday when you spit those 4:10's out the back.
Some simple 10 bolt math:
Drag radials + stock 10 bolt + 4:10 + TR224 =
i'm surpised your rearend is still together right now, even with the stock cam. Do a search for "TSP" i believe they made a post awhile back listing many cams in the works they have. They also already have some info and dyno numbers on a new 225 cam. Check out the numbers it put down in the dyno forum
