LSX 93 coupe drag car build
Old 09-26-2013, 09:52 PM
nastychevelle's Avatar
Default LSX 93 coupe drag car build
Picked this thing up a while ago and am just now getting around to working on it. Goal with the car is mid to high 5's in the 1/8.
First off I would like to thank Sharad at UPR products for the killer suspension parts. I pretty much got the whole kitchen sink from these guys.
Chromoly k member
Chromoly a arms
Pro series coil over conversion with 14x150 springs
Billet caster camber plates
Full length subframe connectors
Torque box reinforcements
Chromoly DA upper and lower control arms
And a pro series anti roll bar
So we ripped out that cherry 60k mile 2.3l engine and trans that was in it to begin with
And removed the old k member, a arms, coil springs, and struts. And installed the UPR k member and a arms.
That's where we stopped so far. I did get some more goodies from the brown truck Santa clause though!
Here is my strange single adjustable struts with the UPR coil over conversion.
Mike Abney over at Nitrous expressed hooked me up with a killer nitrous plate!
Next up I plan to strip the entire car to a shell from all wiring and interior etc.
The car will end up re wired with a leash electronics sportsman wiring board.
Plans under the hood are a SBE 5.3 with a custom nitrous cam, some rod bolts, maybe ported heads, a victor jr with a carb and my plate kit.
Trans plans will be a home built glide and a custom Torque converter from lane over at PTC.
I will update more as the build progresses.
Old 09-26-2013, 11:00 PM
LILHEMI's Avatar
in...
Old 09-27-2013, 08:36 PM
LS1PUNK's Avatar
What are you doing with all the interior pieces?
Old 09-27-2013, 08:39 PM
What are you looking for?
Old 09-27-2013, 09:14 PM
LS1PUNK's Avatar
All the plastics.
Dash, console, trim pieces, etc
Old 09-27-2013, 09:25 PM
All the plastics.
Dash and console are staying.... The rest should be out of the car tomorrow. Ill let you know
Old 09-27-2013, 09:35 PM
lt4malibu's Avatar
what color is the interior? I need a rear seat for a notchback
Old 09-28-2013, 10:21 PM
Got a lot of work done today. Stripped the engine by and interior.
By the time we had it all stripped the front of the car was so light you could see daylight in between the car and the lift pads.
At this point I just have to pick up a 8.8 and do some fabrication and paint work to do while i save some more money. Only things that need to come out now are front and rear bumper supports and door bars.
Old 09-29-2013, 05:48 PM
Picked up a 8.8 rear and a Moser 31 spline lightweight spool today. So this weekend I can clean it up, weld the axle tubes, paint it, and hang it under the car with my UPR control arms.
Old 12-03-2013, 01:46 PM
Sharad's Avatar
So far so good. Can't wait to see how it turns out!
Old 12-03-2013, 02:20 PM
BadWolf's Avatar
updates?
Old 12-04-2013, 02:22 PM
ROBBIEZ91's Avatar
im going to be close to the same build with my notch. Stock bottom end 5.3, custom tick cam that is getting spec'd this week, ported 806 heads, vic jr manifold and carb, 250 shot plate and a glide with an 8.8 and 4500 stall. goodluck man!
Quick Reply: LSX 93 coupe drag car build
