First LS owner Indiana
First off I have had my 1967 Cutlass for about 19 years and have gone thru a couple different motor configurations. From small block Olds to big block 468 Olds. The last configuration consisted of a 468 and 200-4r which I went thru 3 different trans. Was never abusive to then just could never get a good built one. And I eventually wanted to fuel inject it. So long story short tore the whole car down and now building back up from ground up. Frame is done and just finishing the suspension. So I have decided to go to a running LS motor and 4l80e trans. I figure I could run as a daily driver for now and upgrade after it is up and running. So I found a 2003 5.3 out of a Silverado. So I will have a ton of questions on where I need to go and what I need to get to make this fit into my Cutlass.
