Notices
LS2 Crankshaft Crank
Old 10-07-2013, 05:43 PM
SMKE EM's Avatar
Default LS2 Crankshaft Crank
I spun a rod bearing coming out of my garage (hey at least it was home). Not sure why, but think it had to do with low oil level. Was doing a routine fluid check and letting it run in the driveway to warm up, noticed it was 1 1/2qt low, turned it off added synthetic blend oil turned it back on and it spun.
My crank is 24 thousandths under not cut yet. Speed Inc recommends going no further than 10 under so I am looking for a stock crank preferably used.
If you have one in good condition or know someone with one, give me a call/text at 708-415-8936, my names Ryan. Looking to buy ASAP
Thanks
Quick Reply: LS2 Crankshaft Crank
