Coil wiring?
To make a real ling story short, I have a harness that is suspect that has 20 gauge wires going to both the injectors and the coils as the primary power wire. I am getting some misfire issues under boost that I need to cure. Even if it was way fat, it should still light off and it is not. I realise I need to lean it out some more, but with the plugs tapped at 22 it should still light. Those wires are just tiny for the primary ignition wire. I would think 12 or 14 gauge would be better suited.
