limits on3 7681 turbo
got one on my nova with a 5.3 and went 10.15 @134mph spinning real bad on 12.5 pounds and pump gas, 2 weeks ago. makes 499 rwhp at that boost level and had it on for 2 full seasons now with zero probs
Last weekend I ran a 10.78@133.5 w 1.91 60ft on 14psi in a 3200lb fox with my worn out on3 76 with major shaft play.im sure its capable of a high 9 with more boost and launching under boost.
personally don't give 2 ***** bout dyno numbers, what the car makes on paper and what it runs at the track are 2 different things. perfect example I did a cam swap last month from a ls7 to a tick custom turbo ground and picked up 2 hp and 5 tq at the tires on paper, but at the track, picked up 4.5 tenths and 7 mph at the same boost levels. id say that's more than 2 hp
thanks for you guys input.. I really didn't know what the specs on the turbo where but dang I didn't realize the ex turbine was only a 65 and with an .81 ex housing... that's some tight stuff on the back side. Im glad if found that part out reason enough for me to want to make a change..
