Ati double key damper, what does that mean?
Old 10-10-2013, 09:13 PM
Patsy57's Avatar
Default Ati double key damper, what does that mean?
So I have an ati damper and I want to have it double keyed to the crank but not sure what that means? Does it mean two crank pinning kits are used or?
Thanks
Old 10-10-2013, 10:32 PM
97WS6SCharged's Avatar
It generally means you have the crank machined to use two Woodruff keys.
Old 10-11-2013, 12:49 AM
8 Second Truck Club
Blown06's Avatar
Yes, you'll have to pull the crank out and send it to a machine shop to have the slots cut in it.
Old 10-11-2013, 01:41 PM
Patsy57's Avatar
ok crank is out and at a machine shop. just curious as to what it needs since I provided the engine whcih is being redone and the damper, so I was wondering if I needed to buy anything else for this.
Old 10-12-2013, 01:00 AM
8 Second Truck Club
Blown06's Avatar
If the machine shop has the crank and the balancer and can't figure it out from there, you need to find a new machine shop.
Quick Reply: Ati double key damper, what does that mean?
