cheapest place to buy v bands and cupplers
Old 10-10-2013, 09:26 PM
mustang93's Avatar
Default cheapest place to buy v bands and cupplers
Im looking for a 5"v band flange and clamp. A v band flange for a 44mm wastegate and two 3 1/2 rubber cupplers.whats the cheapest place?
Old 10-10-2013, 11:27 PM
janks300's Avatar
i have seen a bunch of cheap v bands on ebay but from experience they tend to leak and not seal well , i would recommend spending a little extra and buy something higher end.....siliconeintakes.com has cheap rubber and it actually is really nice stuff, i am making 20lbs of boost using there couplers with zero issues
Old 10-11-2013, 12:47 AM
8 Second Truck Club
Blown06's Avatar
funny you should ask........I found a 5" v-band (rings and clamps from racepartsolutions) in the garage today. It has the locking ring inside so it is the good one. If you want it pm me.
Old 10-11-2013, 09:18 AM
Sarg's Avatar
Coming from experience, don't go cheap on vbands. I will probably have to go back and redo mine from using some cheaper ones. I am going to try gaskets first.
Old 10-12-2013, 02:20 AM
95bowtie's Avatar
Gaskets work let me tell ya haha.
My 3 inch dp vband was super thin metal but was the only one out of 4 different ebay ones that matched up with the tc7875 exit.
I tacked it in a star pattern then did tack welds all the way around it in a star pattern over about an hours time cooling it off after each one and it sat almost an 1/8 inch off the turbo flange on one side when done
Bought a 3 inch mls vband gasket off ebay for 20 bucks and it seals perfectly
Quick Reply: cheapest place to buy v bands and cupplers
