LT1 Perf. parts...and more. 396, Moser, 4L60E, Vigilante, Brakes, Etc
Category: Accessories
Price: $1234
Part Fits: 93-02 Chevrolet Camaro
Location (State): TX
Item Condition: Used
Engine: LT1/LT4
LS Engine?: Fits LS Engine
ENGINE RELATED
Engine: 396 with Splayed Billet Caps, Callies "Dragon Slayer" crank, Eagle H-beam rods, JE psitons, LT4 timing chain, Huge .673 lift solid roller. Being sold as short block. $2,800 NO LONGER AVAILABLE
ATI Serpentine Balancer for "F-Body" LT1. (27 miles total use)
Steel Hub, Aluminum Shell/Pulley $315 P/N 917268 SOLD
CSI Electric Water pump, Already intalled in donor LT1 water pump...ready to go! SOLD
MSD Billet Optispark, pin drive style.$325 P/N 83811 SOLD
MSD Digital 6AL $175 P/N 6425
Taylor 10.4mm 409 series plug wires (red) $65 P/N 79226
AS&M LT1/LT4 1300cfm Monoblade throttle body. SOLD P/N ASM-6004
AFR Stud Girdle $80 P/N 6200. SOLD
AFR "Poly Lock" nuts (7/16) for above stud girdles $50 P/N 6220 SOLD
ARP 7/16 rocker studs $30 P/N 100-7101 SOLD
Comp Cams 5/16 flat guide plates $12 P/N 4808-8 SOLD
Comp Cams Pro-Magnum 1.6 roller rockers $300 SOLD
Hooker Long Tube headers $225 P/N 2231 Coated but rusty near welds/collectors snd lower tubes. SOLD
Borla Stainless muffler / Quad tips...with Intermediate pipe (not stainless) and "dump" for a "cut out", no cats $175 SOLD
SUSPENSION RELATED
Moser 12 bolt with Wolf Racecraft needle bearing Sway bay, 4.11 Ring & Pinion, 33 spline Spool/Axles, LPW Aluminum Cover/Girdle, Backing Plates, Calipers and Discs. Gloss Black finish. Sway bar mounts were professionally TIG welded to housing. It is ALL done right! Cost $3,000 to duplicate. Asking $2000. SOLD
LAMB COMPONENTS billet front drag brakes: 4-piston Clear Anodized calipers,2-piece rotor with Clear Anodized billet rotor "hat", 12 point rotor bolts, Complete replacement Clear Anodized billet hub w/integrated caliper bracket, S/S -3AN 90 deg. brake hose fitting, All Aircraft grade Fasteners, THE BEST DRAG BRAKES YOU CAN BUY $1895 new. Used ONE weekend. $1,200
LINK TO LAMB BRAKES
Hotchkis Lower Control arms with Poly Bushings $150
BMR Torque Arm with Poly front bushing (red) $260 P/N TA001R
Adjustable Panhard rod: knurled aluminum with aircraft rod ends/spacers. $125
DRIVETRAIN RELATED
Stage IV 4L60E by "Texas Perormance": Sun Coast shell, Red Clutches, Blue kevlar band, Corvette Servo and more. $1200
Pecision Industires - Vigalante Converter P/N 259615. It is a 9.5" Single Disc, Lock-Up converter, for LT motor. Jack at PI told me stall is between 3200 to 3600...depending on power. However, I think it is commonly listed as a 3200 stall. Converter looks like new. $400
ACPT Carbon Fiber Driveshaft.SOLD
Kirban "Kwik Shift" T56 F-Body Shifter.SOLD
BODY SHELL / PARTS
The body was originally Polo Green...but previous owner painted it a medium metallic purple. Underhood area is still green Hood has already been sold. Interior is Tan and black. Seat are Leather, driver's seat cover is cracked and torn. Console Lid hinge is broken. Currently it has Hotchkis subframe connectors. Also, it has 255l fuel pump in tank. Rear wheels have M/T ET streets 26x10.5. Front are Tempa-spares. Since I am removing the 12bolt, I will be reinstalling a 10bolt with 3.73 gears. As mentioned above, the car was running less than a week ago. Although it is ugly and well used, it is still a solid car. All glass is good. Wiring harness is good, I will sell roller AS-IS for $400 if you act fast...as parts will start disappearing soon Reduced from $800!!
So, if you want the whole roller let me know. If you want parts tell me what you want and I'll let you know availability and price.
Also, I have all engine brackets, PS pump, Alternator, Battery, Radiator, etc...everthing that it takes to complete a car.
Near Houston, TX
Contact me via PM or TEXT 7one3-882-4one00
Ronald
Also, Have Complete COLD FUSION "wet" nitrous kit. It was installed, but never used. Bottle has never been filled. Kit includes 4 sets (4 fuel and 4 N20) jets, tunable from 50HP to 200HP. All pieces are in mint condition. Cost was $469...asking $300. P/N CFN-1100
Update on Vigilante Converter:
Made some updates to ad. Moser rearend is now SOLD. I have completed disassembly of the car. Now all parts listed are off of the car. If you need pics of something listed please let me know.
