integra + 5.3=?
That is going to require a lot of custom fabrication....hope your and/or your wallet is ready for the task. The only one I saw in person was an Integra that had used the Honda Pilot or Odyssey rear (cant remember its been like 5 years) and the kid was using it for drifting purposes. The kid and guys that built it were mostly old school Honda heads so they knew their way around them. GL
Sounds like it would be easier to build the frame/engine/drivetrain, then drop the body over the frame. I did something like this some years ago with a Buick Regal frame/engine and a RX7. Your other option is to try and build everything around the body. That is generally a lot of work, but doable.
It really isn't as hard as it seems if you have the place to do it and some good mechanical ability/fabrication skills.
