sump removal
sump removal
Is there anyother way of removing sump from 2012 5th gen without dropping crossmember or removing engine.
If not is it a big job to drop crossmember.?
cheers
cheers
6 large bolts hold the k-member in. You'd have to support the motor/tranny/front suspsension/radiator somehow while lowering the k-member enough to drop the pan. Maybe you could use an engine cherry picker to keep the motor up while lowering the member?
