What is the quietest 4" muffler I can get?
Right now I'm running longtubes, 3 ory into a 3 to 4 FM merge, over the axle into a single 4" magnaflow bullet in the stock location and a single hidden tip on the driver side. Well the car is bareable but I want it as quiet as possible. I plan on doing dual 3" cutouts for the track so the main priority is quiet. Are their anything out there that will shut it up anymore?
I'd consider adding a Dynomax race bullet muffler(# 24217, $50)in the I-pipe if room permits, otherwise I'd look at the Hooker max. flow (#21609HKR, $70), and the
Borla XR-1 (#40948, $203) to replace the Magnaflow race muffler which I believe contains no packing material around the perforated tube.
UDo an oem diesel muffler?? Install a dynatech cone silencer? I had one on my 4" bullet. It fell off a few times and that proved to me that it was working pretty good. No seat of the pants power loss but Im sure it hurt a little.. Do 2 or 3 of those if space is limited.
I forgot to mention I actually have a 4" dynomax bullet in the I all ready and I'm running the 14163 magnaflow. I've been looking at the Hooker Maxflow I just wasn't sure if it would be any quieter than the magnaflow. http://www.summitracing.com/parts/ho...9hkr/overview/
Yeah, the Max flow is suppose to be quieter than the Aero chamber except for WOT.
Here's the only other option that I think's worth looking at. Dynomax Ultra Flo #17537 (6" dia., 22"case length, about $110), this is the longest that's known to fit in the stock location.
The Maxflow I had (single 3") was quiet all the time. I would pull it on and off the car depending on what I was doing. For a long drive, it was awesome to have. Otherwise I ran a dumped dynomax bullet, which is loud.
Do you guys think the max flow will quieten down a noticeable amount over the magnaflow? I probably should have given a little more info on the car. Its a 10.90 M6 SBE car so I suppose it makes a little more noise then your average LS1. I'd just like to be able to drive by cops without worrying to much.
Since you're going to be running dual cut-outs then here's a Option that will work good, but you'll need to run a good 4" to 3.5" reducer before the muffler then another 4" to 3.5" reducer flipped around so you can use your current tail pipe, or you could just get a 3.5" 90* bend and cut the exit end at about a 45* angle and use that as you tail pipe. The muffler is a magnaflow #12909. 3.5" in/out.
http://www.magnaflow.com/02product/s...=main&id=11418
