What clutch should I get
I am going to be buying heads and a cam and eventually nos I was wondering should I get the gm ls7 clutch or a center force I refuse to buy spec or atc have had bad experiences with both on other vehicles
The LS7 is only rated up to 525HP with occasional but not frequent racing. Sounds like your car is easily gonna pass that on spray. I know a guy who had a H/C car with a Monster clutch, maybe the way to go if you're against Spec. I've heard Centerforce is good but no personal experience. If drivability is not a concern get the most aggressive one you can afford. You'll probably want something rated to handle like 600HP with Heads+cam+spray
