Custom Big T6 Turbo Kit HSP Huron Speed
Category: Engine - Power Adders
Price: $1700
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): MI
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
-Kit utilizes Truck Manifolds
-2.25" crossover pipe, true divided into a divided T6 flange
-Includes bungs for primary O2 sensors in the crossover
-Turbosmart 60mm gate flange pulling from both banks of the crossover
-Custom 5" to split 4" downpipes
-Downpipe features a custom tight radius 5" to clear inside the factory frame rail. V-banded before it exits the bumper for easy tip exit install. Bung for wideband installed as well
-Kit has never been ran, simply mocked up
-Was set-up to run Non-Intercooled with a direct straight shot into the TB from the compressor housing.
-Compressor housing is for a S476R BW turbo modified with short cold side pipe with Turbosmart 50mm BOV flange, IAT sensor bung, and drilled for a meth nozzle pre-IAT
-FAST 92mm Big Mouth TB modified with v-band style clamp set-up to bolt to the compressor housing.
-Alternator relocation brackets included
-Kit requires a remote mounted water-pump, or slight modification to factory as the comp. housing will rest on the edge of the snout of the pulley.
-Kit also requires a stood up radiator obviously as you can see where the turbo sits.
-Kit was built around factory power steering
-Kit is coated entirely in Ceramic Black
*Turbo not included
*Wastegate and BOV not included, however we can provide the buyer with NEW Turbosmart units if interested for a terrific price!
$1700 plus $50 shipping includes:
-Crossover pipe
-Custom 5" to split 4" Downpipe with v-bands and 2 exiting 4" tips
-All Ceramic Coated BLACK
+$975 to include the modified Compressor housing, modified FAST 92mm Big Mouth TB w/ IAC and TPS sensor for it.
*If purchasing without the comp housing and TB, you can run a standard BW T6 turbo and just make a simple stubby pipe for it like shown below with the White housing Turbo!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
__________________
Absolutely, it is also so close than you could do some minor trimming and fit one as well. thanks for the info!
__________________
Back up, will accept a reasonable offer on this as well!
__________________
Lets find this a nice new home!
__________________
Yeah, they appear to clear up some good room there!
__________________
Bump!
__________________
Bump! Reasonable offers accepted
__________________
Bump!
__________________
Bump!
__________________
That's no problem! Just don't purchase the compressor housing and tb and make a short stubby pipe for your cold side!
__________________
Bump!
__________________
Bump for new price!
$1750 SHIPPED!
$1750 SHIPPED!
__________________
