Nitrous plug question
Ok I have read every thread I can find on ls1tech and yellowbullet but haven't found an answer. I'm looking for the right spark plug for a 300 shot. I was told NGK B9EFS (#1085) would work but it is a non resistor type plug and will cause noise/interference with the ecu. I can't find a #9 cold plug that is a resistor type. What are you nitrous guys using for a 300 shot? Thanks in advance
Ls1tech & Truck Sponsor
-Garrett
Just got off the Phone with Holley (the car has a holley dominator ecu) and they don't have an answer for this either. They recommend loading it up with dielectric grease and trying my luck.
No they don't call for gasket seat plug, they are stock LS casting heads. The plug ATV mentioned won't work for me but I asked him about the noise/interference because I see it is a non resistor style.
Shiz and others seem confident I won't have an issue, but if so many people are running these style plugs with no misfire issues why is Holley so concerned?
Seems to be an issue for some with the Holley ECU. Here is a post that got a lot of attention on bullet.
http://www.yellowbullet.com/forum/sh...d.php?t=584213
