New 416 vs Street tires :)
Lt`s, catless with Dougs X pipe and BOrla XR1`s all 3"
Little rev action - It revs insanely quick
Here is a 0-130 pull with 4 200# people in the car, and feathering the throttle real bad untill about 80
Ya idc no reace here, just super stoked to have my car back on the road!!
With the Iron block I should be around 3600# without me
They are LS6 heads I hand ported myself, have about 10 hours into just porting. They are decked .010, 5 angle valve job, bowls blended etc.
I plan on it, this vid is on a 275/40/16 street tire, I have some 275/50/15 Nitto 555r`s on a 10" wide prostar that will be going on shortly and hitting the track. I have a problem with reverse I need to take car of first!
Thanks man, I knew it would pick up power but JHC I didn't expect this!
I rolled her over 50 miles, dropped the oil and checked it out and opened up the filter, looked great so took her out and made sure the rings seated
12.5:1?! and i thought i was being on the edge going to 12:1 and wanting to run pump...well i guess if you keep the timing and whatnot pretty reserved you could do that. throw some race gas in that thing and watch the power you make!
