what solid frame pad for hooker swap motor mounts in 2nd gen
found out the solid Moroso frame pad wont work with the hooker swap motor mounts for a 2nd gen (12613HKR). and not having any luck finding info on this. is there a solid frame pad that will work, or an i going to have to ditch the 2nd gen mounts and go with an adapter plate.
found out the solid Moroso frame pad wont work with the hooker swap motor mounts for a 2nd gen (12621HKR). and not having any luck finding info on this. is there a solid frame pad that will work, or an i going to have to ditch the 2nd gen mounts and go with an adapter plate.
the swap is done and i had it running on a carb set up. iv now pulled that all off and goin EFI with a holley high ram, holley dom 1800 pump, holley fuel rails, holley reg, and prob go with holly injs. hope to have it running efi by spring. then hang a turbo off the side of it
