Switching from elbow to 4150?
Okay i have a super vic intake with a low profile elbow & i wanna switch to 4150 setup. Anybody got part numbers & what parts i need to run this setup. Like part number for the hat? & if ill need any other parts that im no aware of like throttle bracket. & what do i do about the mass air flow sensor?
Research...... It's not all that simple, especially when using the Super Vic. What hood do u have???? Which 4150 TB do u want to go with??? Sacrificing your wipers??? N/A or nitrous use comes into highth issues. Cutting up the cowl and hood is a must. Most setups are MAFless and go speed density.......
This is my setup of what I ordered:
Part #
Scorpion 4150 TB $530
28095 Super Vic. $410
3638 Edelbrock fuel rails $110
TC1000U36 Lokar cable(cut to fit) $50
15152 Jegs throttle cable bracket $65
Fel-Pro Q13123 intake gasket $30
RGR501 fuel rail kit from Speed Inc. $110
9749 (2) 45* elbows $40
9849 Spectre carb hat $75
Total= about $1500
Part #
Total= about $1500
Speed Density tune is where you tune out the MAF, as in, you're car no longer uses it and it can be removed from the vehicle. There are countless threads on that topic. I have a Speed Density tune on my WS6 and it drives the same as it did when I had just a regular tune. One is no better than the other and as long as the tuner is good, you won't even be able to tell a difference.
