Stud Girdles on Comp Gold Rockers?
Ok guys, i guess for the time being unless someone makes an offer I'm putting my LT1 back together. I want to squash the polylock gremlin thats been plauging my build since day 1. Im currently running a Comp Gold 1.6 Rocker on my Dart Pro 1 heads with Dart Factory studs. The polylocks constantly back off on these (and yes were setting them right, I promise you). So my question is can I ditch the polylocks and run an aftermarket stud girdle? Will it clear the rockers? Is there any other better solution to eliminate the polylocks?
Thanks!
Thanks!
I ran a stud girdle on LT1 heads for a couple of seasons but found that they were relatively ineffective in my application. There were no issues with the polylocks backing off but they were inadequate in terms of stabilizing the valve train. The valves still required re-lashing after every second or third run and there was evidence that components were moving around at high RPM. A set of T & D shaft rockers resolved the issues for good.
c
c
