Notices
Vehicle Classifieds This an archive of the older vehicle classifieds, please create a new listing in our Marketplace.
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
fs/ft 91 Z28 Camaro turbo 370 LSX 4l80e 738rwhp
Old 10-19-2013, 09:50 AM
4SFEDSS's Avatar
Default fs/ft 91 Z28 Camaro turbo 370 LSX 4l80e 738rwhp
Year: 1991
Make: Chevrolet
Model: Camaro
Price: $20000
Mileage: 85000
Private or Dealer Listing: Private Listing
Location (State): MI
Color: Black
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Im considering selling or trading my 91 Camaro with a single 80mm turbo. I love the car and have a ton of time into it over the past few years while building it but have kinda lost interest in it lately. The car made 738 rwhp 756 rwtq on 13 lbs on pump gas, the car is now running 15lbs and has not been back on the dyno. The motor and trans have only about 500 miles on them. Here are the specs on the car.
Motor:
05 6.0 LQ4 iron block 370ci .030 fully prepped
Wiseco pistons aprox. 9.5:1
Eagle rods
GM crank rotating, assembly balanced
371 heads, lightly cleaned up
LS9 head gaskets
arp head and main studs
LS2 Timing chain
EPP blower cam
Ported and shimmed oil pump
Trans:
4l80E built by CK performance with rossler trans brake
Precision converter with triple disk lock up
B & M deep pan
trans is fully automatic controlled by computer
Chassis and suspension:
Spohn tubular k member
Spohn tubular front control arms
Spohn coil over conversion
LS1 brakes front and rear, drilled rotors in front
Spohn tubular rear control arms
Spohn tubular torque arm
Bump steer kit
UMI panhard bar
BMR panhard relocation for 4" exhaust
UMI subframe connectors
S&W 10 point cage (done correctly through the dash and all tig welded)
BMR rear battery tray
battery shut off in tail panel
Moser 9", Wavetrac diff, 31 spline moser axles
3.55 Richmond gears (has typical gear whine)
Spohn Crossmember for 4l80e
Spohn driveshaft safetly loop
3" steel driveshaft built by CCI, 1350 joints
Interior:
4th gen dash, fully functionally gauges and heat, Check engine light even works correctly, obd2 outlet under dash
Full 4th gen leather interior, seats and console. Very clean, front seat has been converted to allow 5 point harness
RJS 5 point harness
Turbo, exhaust, and cooling:
80mm ST80 Borg Warner based turbo built by Forced Induction
3" aluminum intercooler
304 stainless turbo hot parts (have been ceramic coated)
3.5" downpipe to 4" full exhuast
JGS Wastegate
JGS blow off valve
Aluminum 3 core radiator with dual electric fans
Derale trans cooler with electric fan
Fuel and accessories:
F-body ecm running speed density 2 bar map OS
Dual intank walbro 255's (second pump is activated by hobbs switch)
60lb siemens injectors
Boost referenced regulator under hood
Line lock
Im sure ive forgotten some things and I have some more pics of the underbody showing how clean the car is that I will add later. I would like $20,000 or possibly trade. Some trades I would consider are maybe a cts-v or a G8, or even an ls swap fox body plus cash.
Attached Thumbnails fs/ft 91 Z28 Camaro turbo 370 LSX 4l80e 738rwhp-hpim0670.jpg   fs/ft 91 Z28 Camaro turbo 370 LSX 4l80e 738rwhp-hpim0672.jpg   fs/ft 91 Z28 Camaro turbo 370 LSX 4l80e 738rwhp-hpim0622.jpg   fs/ft 91 Z28 Camaro turbo 370 LSX 4l80e 738rwhp-hpim0843.jpg   fs/ft 91 Z28 Camaro turbo 370 LSX 4l80e 738rwhp-hpim0339.jpg
Old 10-19-2013, 10:39 AM
CutchZ's Avatar
Nice.
Old 10-19-2013, 10:12 PM
greedygenius's Avatar
one of the coolest 3rd gens ive seen GLWS
Old 10-20-2013, 06:37 PM
bp92gsr's Avatar
pmd you
Old 10-21-2013, 09:09 AM
grifter757's Avatar
Damnit i want this...
Old 10-21-2013, 11:05 AM
4SFEDSS's Avatar
Thanks guys, just added some more pics.
Old 10-28-2013, 09:57 PM
Delivered's Avatar
Any track times?
Old 10-28-2013, 10:25 PM
prokilllsx's Avatar
Times 2 ^^^
Old 09-01-2014, 07:27 PM
4SFEDSS's Avatar
Im gonna try selling this again, would consider selling this as a rolling chassis, just want to start a new project. Would love a 62-67 nova, prefer a pro street rolling chassis.
Old 09-01-2014, 09:01 PM
MarcusT's Avatar
Does it have ac?
Old 09-02-2014, 06:48 AM
4SFEDSS's Avatar
Originally Posted by MarcusT
Does it have ac?
no it doesnt
Old 09-03-2014, 01:21 PM
white86z28's Avatar
interested in a cobra terminator ? 03 14k miles ...your car plus cash ontop for mine ?
text 937-903four700 if interested
Old 09-03-2014, 01:49 PM
4SFEDSS's Avatar
No thanks not a ford guy.
Old 09-05-2014, 06:22 PM
Razor's Avatar
Well, I could see the trade for a Nova...maybe.
But, a 'me to' LS swapped Fox, eh.
I'd keep what ya got. From the parts you have listed, looks like a solid street car.
JMHO.
Old 09-09-2014, 07:15 AM
4SFEDSS's Avatar
keep the trades coming guys
Old 09-15-2014, 07:56 AM
4SFEDSS's Avatar
to the top please
Old 10-02-2014, 08:20 AM
4SFEDSS's Avatar
Would like to get 12k as a roller, complete turbo set up and trans could be negotiated into the deal as well. Doesn't get much easier than that, full harness and fuel system will stay with the car, Just drop your motor in.
Old 10-08-2014, 07:40 AM
4SFEDSS's Avatar
Im getting anxious to start a new project. to the top
Old 10-14-2014, 07:34 AM
4SFEDSS's Avatar
I can add cash for a descent trade.
Quick Reply: fs/ft 91 Z28 Camaro turbo 370 LSX 4l80e 738rwhp
