2 pin oil pressure sending unit wiring
Ok, I am trying to run a wire to the 2000 camaro z28 gauge that I have. There is one input for the oil pressure. The oil pressure sending unit I have has two wires coming out of it that are identical colors. Anyone know how this is wired? Any idea which of the two wires I take to the gauge cluster? From what I have been able to search and find, the other wire coming out of the sending unit just goes to ground. But I do not see any distinguishing marks on the wires to tell which would be which.
Awesome, I will check that tomorrow. Although after writing this, I finished up the rest of the wiring on my f-body gauge cluster and while the needles will sweep, apparently that is about all that happens. Apparently I bought a bum cluster. Very unthrilled.
Could not even GET to the sensor any more, lol. I would have to put the intake, but trial and error, one was to go to the gauge and one to the ground. I did look down there and there were no distinguishing marks that I could see. And apparently it DOES matter which one you hook up. Thank you for the help!
