Another failed exhaust flex pipe
Old 10-20-2013, 06:58 AM
locospl's Avatar
Default Another failed exhaust flex pipe
Just pulled the passenger X-over off of my front mount to change turbos. This is what I found lurking in the pipe. Glad it did not make it to the turbine yet.
Now I have to pick up a new turbo flex section and tig it in.
Old 10-20-2013, 07:32 AM
yenkomike's Avatar
that's why I just went with a slip fit in the pipe and use a band clamp so it can give a little.seen to many posts like yours but most took out the turbo. good catch.
Old 10-20-2013, 07:45 AM
Blackpanther99's Avatar
Wow... Lol. Just get a slip fit in this time, its better and you wont have to run through that issue.
Old 10-20-2013, 08:04 AM
SS2win's Avatar
Is that even rated for turbo application? What's up with the braided center?
Old 10-20-2013, 08:15 AM
Old Geezer's Avatar
Talking Exactly what
I am thinking.
Don't think the braided inner liners are rated for hi EGT's..
The wound, SS flex liners are.
Old 10-20-2013, 09:06 AM
boostnut's Avatar
Originally Posted by Old Geezer
I am thinking.
Old Geezer nailed it. The flex's with inner braided liners aren't worth a $hit for a boosted application. Replace it with one that has an interlock liner and be done with it. See here: http://vibrantperformance.com/catalo...Path=1022_1064
I've got customers using the 2" coupler with an interlock liner on boosted 6 liter ford powerstrokes making big, big boost with several hundred in service and only 1 documented failure.
Old 10-20-2013, 02:04 PM
3pedals's Avatar
I made my x-over solid, no issues
Old 10-20-2013, 08:04 PM
locospl's Avatar
Yeah it was not a turbo rated flex joint. My drivers side pipe has a slip fit it in it but the passenger had this flex piece in it. I have ordered on of the turbo rated ones with the interlock liner. Once I finish the turbo swap I will see if I want to go flex or slip.
Old 10-20-2013, 10:12 PM
Ralls's Avatar
I've had this problem twice so far. First flex coupler was braided inside
I bought the Vibrant interlock one the second time and it still did it. Has a really bad exhaust leak coming through the coupler and loosing boost. Pieces were missing and I'm surprised my turbo hasn't got hurt yet. I'm about to try my 3rd attempt this time. As you see, my coupler is coming right off the header. I'm thinking the heat from the header is killing these. I'm going to try to move it further downstream to see if that helps.
Old 10-20-2013, 10:39 PM
locospl's Avatar
Most likely I will just do another slip joint in the passenger x-over, as I will be wrapping the hot side this time.
Quick Reply: Another failed exhaust flex pipe
