engine harness problems
Alright, so i have a 4.8 going into my camaro, going turbo, anyway, how would i go about wiring this? the truck wiring harness has the fuses all connected, the car is different. and if i go with a fbody engine wiring harness, what pcm can i use. And can it work with all the truck sensors? I have the truck pcm, its a 2006 pcm, but i dont have the car pcm. any ideas will help!
other slight issue that you will need to work out is whether or not you are going DBW or DBC. You mentioned 2006 ... that's a DBW (drive by wire) throttle body. If your keeping the DBC (cable throttle body), just keep the camaro harness and hook it up to the 4.8. Otherwise, going DBW will probably involve a whole nother can-o-worms.
