Got my 383 running with 6010 and e85 got timing questions
Hello all I finally got my 383 ls1 running in my jeep m715. Runs good. It has a victor jr intake. Quick fuel 750dp e85 carb calibrated by them. Have the Ngk 7 plugs gapped at .030 I have timing set at 0-15 degrees from 0-1000Rpm starts up and idles good. And from 1000-1500rpm 15-35degrees and 35 degrees from there to redline. How's that for timing? I'm having a converter issue doesn't let it rev up in drive but was told it can be a tune issue. Monday I will buy a afr gauge. To see how my afr is looking.
In-Zane Moderator
I would probably open the plug gap to .035 on a 6 heat range. The timing might want another degree. That fuel is like 106 octane. You are running timing and a gap that I run on nitrous(timing before I pull 5-6 degrees).
Get a little more aggressive and see what it likes. The BTU burn on that fuel is much slower than gasoline from the pump.
i run a custom 1000 holley e85 carb by eric at horsepower innovations on a 6.0 with square port heads. i don't have any issues with spark as i run a big hvcII coil, which will throw a spark with a burnt off plug strap. i make the same power from locked out 20 to 30+ timing, but run on lower side.
that 750 sounds on the small side, but should still work.
I switched it to 37* max timing runs better. A lot better .84-.90 afr on wot .73 on idle don't like it too rich on idle. Tried messing with it got worse. But it's good now. The converter still don't let it rev up. I ordered a 4000 stall. Should have it in Tuesday. Button stuff on it and go to glamis next weekend.
personally think its nothing to do with convertor. i'd be checking fuel and ignition first.
just little things like float level, needles not sticking, jet extensions etc.
My float level is half in the sight glass my redline is 7000rpm goes up in nuetral and park like nothing. My afr is good on wot. Too rich on idle thought. I don't know how to check the jet extensions and needles I'm 23 this is the first motor I have really messed with.
sounds good so far. take the rear bowl off, some people (me included) use extensions that project the jets to the back of the bowl so they don't get uncovered during acceleration. the seat and needle allow fuel into the bowl (the tab on the float will open/close it). basically if the float level drops during abrun then you need to upgtade. i run 108 sec jets and they suck heaps of fuel, had to go to 150thou needle/seat.
239/242 .640 .638 112lsa 12.5 compression.
Took the rear bowl off this morning. Everything looked good. But when I put it back. It seamed that when I give it wot. The front squirters. Squirt as I accelerate. And the rears squirt as I let off the throttle not as I accelerate.
Check that.
I checked it it's exactly like the front one. Also I finished the converter install and man it's a biggg difference. Burns out from a standstill with 37s pretty good. But I know I don't have the motors full potential. It still doesn't want to go to 7000 too much yet. Runs way better though.
