Road Racing Road Course | Autocross
Fuel starvation/ hard cornering?
Old 10-21-2013, 04:25 PM
ur-n-8's Avatar
Default Fuel starvation/ hard cornering?
I've done some searching and all I've found is something called a "swirl pot" and a reservoir with a second pump. Any ideas for a forth gen?
Old 10-25-2013, 01:42 AM
kmspruill242's Avatar
Are you having problems with it now? I've got the factory tank in my car and I've run it REALLY low on fuel and never had any problems.
Old 10-25-2013, 01:53 PM
ur-n-8's Avatar
If I'm below 1/2 tank the motor wants to die.
Old 10-26-2013, 08:24 PM
Info on the car? Stock, Modified, what year, plastic or steal tank?
Old 10-28-2013, 07:42 PM
ur-n-8's Avatar
02 ls1 tank put into a third gen ls1 swap. The pump has been replaced with a dorman. LS motor is stock.
Old 10-28-2013, 08:17 PM
There are a feed, return, and vent line on these tanks. Have you set them up basically like they where stock? These tanks need a vent line to breath.
Old 10-28-2013, 10:00 PM
ur-n-8's Avatar
I used directions from thirdgen.org. The vent on the tank is intact. I was wondering if a different white housing around the pump is needed?
Quick Reply: Fuel starvation/ hard cornering?
