Fuel System Recommendations?
Hey guys, so I'm about to get started on my D1SC build and need a good fuel setup. I'm going to start out with just 8# on the stock block but I only want to do a fuel set up once with 600+ hp as an end goal.
So what kind of systems do you guys run or recommend for a 600+ FI car?
Edit: I already have 60# injectors.
either dual 255 pumps in tank, or a 255 in tank and a 300lph or slightly larger external. -6 feed or -8 feed; and -8 or -10 return with a FUEL PRESSURE REGULATOR set for 1:1, manifold referenced.
keep in mind, every pound of boost you are pushing back on the injector flow, reducing the effective pressure, reducing the injector flow. This is why people do FPRs
