Twin 76mm turbo kit
Twin 76mm turbo kit
Category: Racing Parts
Price: $5000
Location (State): KS
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Best pass this year 8.32 at 171.99 with a strong headwind and only a 1.4x 60ft. The kit has around 2500 miles on it and works great on the street, spools great.
2 Turbonetics TC76 mm turbos .81 housings
2 Precision 46mm wastegates with 1.5lb springs
2 RPS 50mm blow off valves
3" bullet mufflers with 3" downpipes that exit in front of front tire below the fender
Bungs in each downpipe for wideband sensors
Stock manifolds with vband clamps
2.25" pipes to turbos
Treadstone air to air intercooler
titanium turbo blankets
4" inlet elbow and 4" air filters(ran times with filters on so will flow plenty without restriction)
Oil feed and return lines
All coldside t bolts, couplers
https://ls1tech.com/forums/forced-in...uilt-year.html
Also willing to sell hotside/coldside only if someone wants they could put smaller turbos in(like some 62's) if you have a smaller motor or don't need this much power or with VERY minor modifications could put precision billet 7675's on it and have a 185+ mph kit.
Here is a few from when we was buliding it(had precision 6766's originally)...
is this on a stock kmember (would it fit the same with an aje) and also is the only modification to the car to get this to fit, to cut out the area where the turbos go into the well... how are the turbos mounted, are there brackets that come with it, or do these have to be made and welded to the car? anything major need to be done to the front end for it to fit with the headlights, etc?
this would be my first turbo setup, that i am installing myself, so sorry if the questions are silly...
what are you looking to get for the setup (everything), minus the turbos?
