HUUUUGE Garage Sale!!! Nitrous and other go-fast parts, OEM GTO stuff, and much more!
Category: Accessories
Price: $0
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird, Front wheel drive vehicles
Location (State): CA
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block, Big Block
LS Engine?: Fits LS Engine
I finally moved on from the goat after 7 years. I didn't realize just how much stuff I've accumulated over the years and need to clear out some space in my garage. Below is a list of what I've got so far (sold items moved to the bottom). Everything is used unless otherwise noted.
-10lb nitrous bottle - no leaks, does have a couple of scratches in the paint that can be easily painted over if you’re picky - $115
-Nitrous bottle mounting brackets for 10lb bottle – rubber coating has started to peel in a couple places - $20
-NOS Nitrous Solenoids and Purge Kit – comes with 25ft braided line and 100hp jet - $175
-42lb Fuel Injectors – LS2 direct fit - $275
-LS1 to LS2 fuel injector adapters (new) - LS1/LS6/LT1 (EV1 connector) to an LS2/LS3/LS7 (EV6) - $45
-ZEX Bottle Heater - p/n ZEX-82006 (new) - $125
-K&N Filter – Custom size – Used with the nitrous kit, so it has a 1/4" hole in the rubber (shown in pic), slightly smaller than the above and needs to be cleaned - $20
-K&N Filter – Custom size – Used with the nitrous kit, so it has a 1/4" hole in the rubber that I sealed with waterproof silicone - ~15k mi - $20
-Colgan Car Bra + Side Mirror Covers - $165
-Red Interior Panels (Front 6 - no rear panels) - $250
-06 Tail light - Left only - $100
-Factory GM rear differential fluid additive aka friction modifier (new - unavailable anymore from what I saw) - $30
-Stock Intake Elbow - $20
-Stock Style Panel Filter - used less than 3k miles - $10
-Stock airbox intake extension arm – Free (buyer pays shipping)
-Stock Door Lock Actuator - driver side complete assembly (new) - $99
-Stock Fuel Rail Cover – the plastic tab is broken as shown in the pic, but it still stays on with the rubber grommets - $60
-Edelbrock Bolts - p/n 8524 (new) - $25
Too many pics to upload, so here is a link to pics of all the parts - http://s233.photobucket.com/user/LS2...0Garage%20Sale
Open to fair offers (no lowballing) and if you want more than one thing we can figure something out. These prices do not include shipping. Whatever UPS or the post office charges me is what I will charge you. Paypal is acceptable. Cashier’s check or MO is preferred though. If a CC/MO makes you nervous, just search “GoatRun” on the boards for credibility.
Thanks for looking!
-Nitrous Outlet Bottle heater kit - wiring and accessories included - Sold
-Nitrous Outlet Smokers Package Switch Panel (pre-wired for easy install) - Sold
-SCSS Gator Pod - Sold
-SCSS Nitrous Pressure Gauge (Red) - Sold
-Trick Performance P Gauge - discontinued and impossible to find! - Sold
-Nitrous Pressure Sender Unit, Braided Line and Fittings - Sold
-Fuel Pressure Sensor, Braided Line and All Fittings (for easy/hidden install) – needed in conjunction with the P gauge to read FP and adjust PSI failsafes - Sold
-Nitrous Outlet Remote Bottle Opener - wiring and accessories included - Sold
-Lingenfelter (LPE) CAI + Custom K&N Filter - Sold
-K&N Filter – Custom size - Fits the GTO and any GM TPI throttle bodies (new) - Sold
-PFYC Custom GTO Car Cover – Silverguard Plus ($214 new) - Sold
-Stock Front License Plate Mount (no hardware) - Sold
-ARP Intake Manifold Bolt Kit p/n 154-2001 (new) - Sold
-ARP Stainless Steel Valve Cover Bolts - p/n 400-7506 - Sold
-Saris GTO Roof Rack - Sold
-Stock Exhaust Tips (perfect condition) - Sold
-Stock Rear Sway Bar Bushings - Sold
-Stock Radius Rod Bushings (no leaks) – Sold
-Stock Rear Crossmember Bushings (no leaks) - Sold
-Lovells Crossmember Support Bushings - Sold
I actually just moved up to Portland, OR. I do still have the red interior (assuming that's what you are talking about?). Shipping is just under $100 via greyhound. LMK if you have any other questions.
