M29 with different 5-6 possible?
Ok, so my car decided to stick in 4th yesterday and didn't want to go into any other gear but neutral and 4th, limping it home, I was able to finally get it out and drove home fine using the other 5 gears (avoiding 4th again). After doing some searching on the interwebz it appears that a key may have broke? Either way, I guess it's time to tear it down, so I figured that now is the time to get the better 5-6 gear ratio, hopefully the GTO .84/.55 ratios. Is this possible, and if so what parts do I need?
Also, what else do I need to replace/upgrade while I'm in there? (Already have steel shift fork) Thanks!
