Crank Balancer Question
Okay may be stupid question but i wanna make sure. I had my motor stroked out to a 383 & the new crank doesn't have a moon key. Don't you need one to keep the balancer from spinning on crank? Cant remember if the stock crank had one?
depends on if its a Stock Level Crank or a High Performance Crank....
the Woodruff Key slot can be cut into it while its in the car with a special tool
its not necessary on a Naturally Aspirated LS engine with a V-Belt
the LS Crank is an "Interference Fit" Damper.
if you have a crank pulley that has a keyway, and you want to utilize it, you can buy the ATI Crank Pinning kit and add a sideways pin to the crank that will utilize the Keyway
if you go to a supercharger and need to pin the crank...there are 2 ways to do it...Sideways(as mentioned above) or from the front.
if you pin from the front... Just remember... if you ever have to remove the crank damper, you will probably not be able to get it to line back up without a LOT of luck., the sideways pin is easy to line back up when you need to remove the pulley for any reason.
also, conversely.. if you need a Keyway put in a Pulley....
call a local Machine shop and ask them to "Broach a Keyway" into a pulley for you...
they will have to take a 1.5" bushing, and shave it down a little to fit inside the Pulley, but most of them are willing to do it since its just a few thousandths ...if not, tell them you are willing to pay for a replacement bushing which is around $15
some shops will tell you that your pulley is too hard and it has been heat treated and cannot be broached.....
but I just had an ATI pulley(which has been Hardened) Broached with a 2nd keyway...and it was not an issue...
so if thay say they cant do it... keep calling around till you find somebody who will do it...
