Notices
Vehicle Classifieds This an archive of the older vehicle classifieds, please create a new listing in our Marketplace.
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
2002 SS camaro
Old 10-25-2013, 04:20 PM
petko's Avatar
Default 2002 SS camaro
Year: 2002
Make: Chevrolet
Model: Camaro
Price: $17000
Mileage: 32300
Private or Dealer Listing: Private Listing
Location (State): IN
Color: Red
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
2002 Limited Edition SS Camaro 450 rwhp
I believe only around 7000 miles on engine and parts
HKE Built 6.0L 422ci
Trick Flow 235cc Heads - CNC Ported - (Hand Port Matched By Greg Good to Manifold) - 355CFM
Dual Valve Springs
Titanium Retainers
Fast 92MM Manifold (Hand Port Matched By Greg Good to Heads)
Nick Williams 92MM Throttle Body
Speed Inc 5/16” diameter, 7.400” Long Moly Pushrods
Shaft Mount Yella Terra 1.7 Ratio Rockers
Hell Fire NITROUS Rings
ALL Billet Rotating Assembly ( 6.20" Eagle H-Beam Rods )
Custom Forged Pistons With Offset Rings For Big Nitrous
Melling High Volume Oil Pump
TSP 1 7/8” LS1 F-body Headers
ARP Bolts Top-Bottom Including :
ARP Main Studs
ARP Head Studs
ARP Cam Retainer Plate Bolts
ARP Harmonic Balancer Bolt
ARP Flexplate Bolts
Custom Forged 4340 4.125 Stroker Crankshaft
Comp LS1 Custom camshaft
Factory rockers
Double Roller Timing Chain
LS3 High Flow Water Pump
LS6 Mass Air Meter
SLP Blackwing Air Intake
K&N Intake Filter
LS3 Ingnition Coils
SFI. Underdriven Dapmner
Fuel System:
New GM Fuel Pump Module & Sending Unit
Aeromotive 340 Stealth In-tank Fuel Pump
RaceTronix Upgraded Fuel Pump Wiring Harness Kit
Siemens 60Lb Fuel Injectors
All Chromoly Suspension:
BMR Adjustable Torque Arm
BMR Tubular Subframe Connectors (welded)
BMR Drive Shaft Loop
BMR TH400 Transmission Mount W/ Relocated Adjustable Torque Arm Mount ( takes load off trans. tailshaft)
BMR Lower Control Arms
BMR Upper Panhard Bar & Relocation Kit ( for 3" Exhaust over the axle)
BMR Adjustable Lower Panhard Bar
BMR Lower Control Arm Relocation Brackets (welded to housing)
Transmision:
TCI Built TH400 W/ Transbrake P/N-212506 ( Never Used Trans Brake)
TCI Reverse Manual Valve Body
TCI Deep Pan (+2 Quarts)
32 Spline 300M Output shaft
Strange Engineering 1350 U- Joint Yoke
B&M Transmission SuperCooler W/ Custom Mounts
Hughes Racing SFI Flex Plate
Coan Racing Convertor - 2800 Stall (Very Stock Street Manners)
Rear End:
Strange Engineering Built 12 Bolt
Strange Engineering Forged Center Section
Chromoly Axle Tubes
33 Spline Strange Axles
9 Inch ends (C-Clip Eliminator)
Eaton Posi W/ Carbon Fiber Clutch Pack
Ultimate 12 Girdle Cover by LPW
3.42 Ratio HD Racing Gears
ABS Upgrade (Keeps GM 3 Ch. ABS)
Lucas Fluids W/ Friction Modifier
Driveshaft:
3.5" Aluminum Shaft (Balanced)
HD 1350 U-Joints
Misc:
New Battery
Center Mount Stainless Exhaust by SLP
Custom Offroad Mandrel Bent Y-Pipe ( Ceramic Coated)
Custom 3" Stainless Mandrel Bent Intermediate Pipe (Tig Welded)
Custom SLP SS Grill- One Of Only 3 Prototypes Ever Built
Attached Thumbnails 2002 SS camaro-camaro-2035th.jpg   2002 SS camaro-dsc_0031.jpg   2002 SS camaro-20130905_171258.jpg   2002 SS camaro-20130905_171319.jpg
Old 10-26-2013, 10:30 AM
NAws6's Avatar
Bump for a great looking car!! Wish I wouldn't have bought mine a while ago!
Old 10-26-2013, 04:31 PM
TEXASLESS's Avatar
Nice car and build...The Grille has 4 openings ? I assume the foam bumper support is removed? I've never seen that before...Great price for that amount of work and miles on car...You need to post this in the 35th le forum also...
Old 10-27-2013, 06:04 PM
wile9coyote's Avatar
Very nice - sent you a pm
Old 10-27-2013, 08:31 PM
BES Stroked Nova's Avatar
where is the nitrous ring on the pic? and why was this car posted twice???
Quick Reply: 2002 SS camaro
