Mustang LS swap, good place to mount PCM?
One of my customers cut a square hole in the cowl and mounted it so the connectors are under the hood and the main body of the PCM is under the leaf screen.
I don't really see that happening because the ford ecu is smaller and plugs for it are in the narrow end facing up. The GM plugs are in the long side facing out.
If you opened up the area quite a bit, you could do it, but before stuffing it in there for good, I would make ABSOLUTELY CERTAIN that everything is working PERFECTLY..
Well I don't believe that its going to mount in the original ECM location, I am going to see if there is room between the ac box and the transmission tunnel once I get the dash back in.
