Head Gasket
Old 05-05-2004, 07:14 PM
DD966's Avatar
Question Head Gasket
Looking for MLS gaskets. I can't seem to find the specs using the SEARCH link.
1. Does a sponsor have them for 2001 heads (241 casting), if so, which one?
2. What's the thickness?
3. Does anyone know the width of the fire ring?
Thanks in advance
Jim
Old 05-05-2004, 07:23 PM
Linear Velocity's Avatar
I just ordered a set from SDPC2000.com you can find them ------->. I also have 01 241 casting heads. I believe they are the stock graphite and are .054" thickness. Hope this helps.
Old 05-05-2004, 10:17 PM
triumphman's Avatar
you cant use a mls gasket on pre 2002 heads unless its a ls6 head, they will leak externally where the notch is on the outside of the cyl. head[water will seep in beteween the gasket layers to the notch]
