Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
4l60e vs. 700r4 on carb'd LS1???
Old 10-27-2013, 06:12 PM
FLYNAVY30's Avatar
Default 4l60e vs. 700r4 on carb'd LS1???
Its time to settle on a transmission for my carb'd LS1 thats goin in my '72 C20 Suburban. I already have the bowed flex plate with the wallowed out holes, required Tq converter, and the adapter for the crank snout. My question is, for my application, is it worth going with the 4l60e and dealing with the cost associated with the stand alone controller that will require a throttle position sensor not to mention either the $300 adapter to run my old school mechanical speedometer, or swapping my gages to something more modern.
As far as Ive read, the two transmissions are identical outside of the computer, so whats the benefit of one over the other. This is a daily driver so Im looking for reliability and simplicity, not concerned about horse power or track times.
Lastly, if I do go with the 700r4, what else do I need to get it to work? My current set up is a th350 with column shift.
Thanks for the help!
Old 10-27-2013, 06:49 PM
bears416's Avatar
With a 4l60e I believe u dont have to worry about a stupid throttle valve thats on a supe weak 700r4, 700r4 are extremley weak IMO
Old 10-27-2013, 07:27 PM
snook's Avatar
90-92s are the same as the 4l60e, they just aren't electronic. I have run a 700r4 behind a mild v8 for years with no trouble. You do have to have the cable adjusted right, which is why most people ruin them and call them junk, lol
Old 10-27-2013, 07:38 PM
FLYNAVY30's Avatar
Fair enough...I've got a rebuilt 96-98 4L60e sitting in the garage, I was just looking at the mounting expense of the TCI controller, TPS sensor, and then some sort of speedo adapter and thought the 700R4 might be the cheaper and simpler way to go....after selling the 4L60e
Old 10-27-2013, 07:44 PM
snook's Avatar
Id just stick with the 4l60e if I already had it.
Old 10-27-2013, 09:54 PM
383lt1impala's Avatar
Get the rossler manual box for it 300 it's plug and play makes it full manual.
Old 10-27-2013, 10:02 PM
In-Zane Moderator
ZONES89RS's Avatar
4l80 and never look back.
Old 10-28-2013, 08:15 AM
FLYNAVY30's Avatar
Is that the "hybrid manual valve body -little black box" listed on their web site? They don't have any additional info listed. What exactly does that do for me? (Excuse my ignorance, this is my first build using an automatic)
Old 10-28-2013, 08:58 AM
It's no problem ask questions that's what a forum is all about. Well it connects to the transmissions main plug then you connect two wires one goes to ignition power. The other to a ground switch when ever your in 3rd and 4th. You ground it and it locks the converter. When you have to manually shift it. Start in 1st. When you need it shift to 2nd and so on. I used it in my jeep for 2 years now works great.
Quick Reply: 4l60e vs. 700r4 on carb'd LS1???
