Need info on "6 bolt/4 bolt" motor. General nooB info.
Old 10-28-2013, 01:36 PM
a.white86's Avatar
Default Need info on "6 bolt/4 bolt" motor. General nooB info.
Some know I posted info about my front mount turbo setup i'm planning.
My question is, I read about 6 bolt only for big boosted applications. I was planning to use my LS1 aluminum block for a front mount, 76/91 setup, would be happy anywhere between 800-1000hp. But, my LS1 is a 4 bolt right? What blocks are 6 bolt setups? And do different heads go with different bolt patterns?
Old 10-28-2013, 01:52 PM
DEFYANT's Avatar
Any factory LSx block utilizes a 4-Bolt per cylinder setup. The Chevrolet Performance LSX, the ERL Performance SuperDeck I & II, the World Products Warhawk, the Dart LS-Next, the Dart Billet, the RHS, and the LSM Billet are all 6-bolt setups. You can use 4-Bolt heads on 6-Bolt blocks, and vise versa.
Old 10-28-2013, 02:00 PM
a.white86's Avatar
ahhhh ok that explains a lot to me. So my block can utilize "6 bolt heads" then.
I ask because I hear of boosted LS's lifting the heads up off the motor regularly, and using a 6 bolt head should be manditory.
What heads can I use, that are 6 bolt? 317?
Old 10-28-2013, 02:05 PM
Jenson's Avatar
6 bolt heads will fit a stock block, but you'll still only have 4 used. Must send it to ERL to be modified. There are no 6 bolt factory heads either.
Old 10-28-2013, 02:07 PM
DEFYANT's Avatar
Yes you can utilize 6-bolt heads, and no, there are no 6-bolt 317 heads. AFR, TFS, Mast, AllPro, all aftermarket manufacturers have a 6-bolt options. A 4-bolt setup can live to 1200hp if tuned properly.
Old 10-28-2013, 03:12 PM
jasond26's Avatar
Well Gm offers the LSX series heads that are 6 bolt (LS3,LSA,LS7). They use factory components they are just 6 bolt. Really the only reason to get 6 bolt now is if you plan on upgrading the block in the future. I guess if your buying new then getting them now would not hurt.
Old 10-28-2013, 06:13 PM
Formerly 4mulaJoe
LS1x2's Avatar
I've found 6 bolt heads to not be needed at my power level of 950rwhp. I've done some long pulls with it too. You want a head with a thick deck and no thin spots. Cheapest option I believe is 317's. I went with AFR 225's. You've gotta be conservative with the tune. What you get away with on the dyno isn't real world.
Old 10-28-2013, 06:16 PM
symerton's Avatar
Yes the 6 bolt heads will work on your 4 bolt block.
But you still only have 4 bolt clamping force with 6 bolt heads on your 4 bolt block.
Old 10-29-2013, 12:35 AM
a.white86's Avatar
Thank all of y'all for the info. I appreciate it, and you'll probably see me posting with more questions periodically.
Thanks again.
Quick Reply: Need info on "6 bolt/4 bolt" motor. General nooB info.
