MeanWS6
01-20-2003, 09:41 AM
Can anyone recommend what size injectors to get with stage II H/C and 150shot?
383LQ4SS
01-22-2003, 03:47 PM
What kit are you going with. I am assuming it is dry kit? I am also assuming you will be right around 415 rwhp? So that will put you right around 550-560 rwhp.
According to RC engineering calculator you should be ok with 36 lb/hr injectors.
Stock fuel system correct? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
beardWS6
01-22-2003, 09:50 PM
I was told the stock fuel system will handle 425-450 rwhp. Anymore and your pushing it! I went with a in-line fuel pump and 30lb injectors. I have no fuel issues at all. Safety is the key. Better to have to much than not enough. Running rich isn`t bad, running lean is! You can see in my Sig what I run and my numbers. If your a dry system things change alittle. Mine is a wet set-up. I love it!
