Manifolds for a 65 impala with a 5.3?
Putting together a 65 impala with a 5.3. I'm using the holley pan and transdapt mounts. I know you can use the camaro headers but this car is gonna be a total driver and manifolds will suite it better. Does anyone know what will fit it? I have a set of trucks and they hit the steering box.
I am doing a 65 Bel Air and was going with manifolds, but also have not found any that will clear the factory steering box. Dynatech 69 Camaro swap headers fit for sure. I know that kwhizz got a CPP (Classic performance) steering box and 2010 camaro manifolds fit, but I do not think they will work with the factory box.
Hope this helps
Hope this helps
Honestly it looks like Hooker designed those after the TBSS manifolds cause they look just alike. I couldn't see those sitting further away from the block than the TBSS ones so im positive they would fit! I would have bought those if I hadn't remembered that I had these sitting around.
You guys think a truck manifold would fit on the passenger side of a 65 without a/c? I have the driver side manifold from a 5.3 envoy (same as tbss) to clear the steering box, but I'm hoping to run the Silverado manifold on the passenger side. Any thought? Thanks.
It will. I have a 66, tried it on mine. I ordered both Trailblazer manifolds so I'm using those, but the truck one will fit on the passenger side.
That's what I was guessing, but it's great to ask someone with 1st hand experience. I was banking on the Silverado manifold working out as it is the only thing I have for the passenger side right now. Thank you.
