Are injectors good for e85 if I'm currently at 60% duty cycle
Just a quick question. I want to go ahead and start using e85 on my 408 while I finish up my turbo set up. I'm currently at 60% duty cycle at wot on 42# injectors. Just want to know if I'll be good with these injectors. And any idea how much more power I can squeeze out going e85? Last dyno I made 511rwhp on motor
injectors
they would probably just work and wear out or fail. The 60# is a work horse and can handle future upgrade. with a pump /booster they wil get the fuel to the top in more than dyno pulls. this is for gas and meth . E85 has to supply like 30% more fuel. 85# is more the fit. Yes they can be scaled down to gas.
just my opinion
just my opinion
Ok so say e85 uses 30% more fuel. And my injectors are currently using 60% of their potential. And you don't want to go over 85% right? And you would think 60+30=90 but it's not. 30% of 60% is 18%. So with my injectors working 18% harder I'm should then be at 78% duty cycle.
Unless there is another reason why they won't work. Just seeing if I'm over looking something.
I'm not worried about the pump or fueling. That's handled
Yes they would be ok for the time being. Just dont push any harder.
although different injectors can behave differently at higher duties. Some wont like over 80% or so, some will still be quite happy at 95%
But given length of time at these duties would be pretty low, it isnt a major issue unless you intend doing lots of top speed runs, or holding max load/rpm for extended periods.
pushing anything to the limit insures breakage. at least now the take outs are marketable to offset new ..
kind of like going over 7psi on boost on stock ls1's. it is only one bad tank from a broken ring land.
i was using 96's on my car and from pmp to e85 i ran up 39% and had to wick up my pump pressure which was only a bandaid i switched back to gas because screw paying another 1k for injectors
