Stock 5.3/6.0 truck heads turbo 700hp
Old 10-29-2013, 09:56 PM
ElTeto19's Avatar
Default Stock 5.3/6.0 truck heads turbo 700hp
How to make my 5.3 block with 6.0 truck heads 700 hp on the wheel. What do I need to reach my goal.
Old 10-29-2013, 10:00 PM
PaulC's Avatar
All you need are hopes and dreams, baby.
Old 10-29-2013, 10:12 PM
Fast86z's Avatar
I'm going to go with an 80mm turbo, valvesprings, headstuds, rodbolts, camshaft, upgaded fuel system, race gas or e85, and 20psi?
Old 10-29-2013, 10:36 PM
ChevyCamino79's Avatar
I built a Gen iv 5.3 with stock 243's, added Harland sharp rockers, LS7 lifters, push rods, ARP head studs, ARP rod bolts, 96lb injectors, custom grind Cam, LS9 gaskets, Fast 102, T-76, running E85 through a 9" and a TR6060. I am expecting to be in the neighborhood of 700RWHP running a good amount of boost. Will post solid numbers when she goes to the dyno.
Old 10-30-2013, 04:52 AM
9 Second Truck Club
stock48's Avatar
Several different ways but a Simple combo would be: S475, Intercooler, JFR Isky triple 12 cam, pac or Isky valve springs, 91 oct and meth inj, or E85. Head studs, and LS9 gaskets would be a good idea. As said above it will prob take 18~20 psi of boost with the lower compression. A Customer of mine today with a stock 317 headed lq4, S475, triple 12 cam, on 91 oct/meth inj @15 psi go 727 thru a 4L80E on a conservative tune.
Quick Reply: Stock 5.3/6.0 truck heads turbo 700hp
