Anybody done a can-bus dash?
I am trying to find a set of can-bus compatible gauges to use in my GTO. It is obvious that the technology is there, I just can't seem to find the product. Any ideas are very welcome. I will need a cluster of 3 3-3/8", comprising a tach, speedo and a 4 in 1, OP, WT, Volt and Fuel. It would be ideal to have a message center with A/F and boost.
Try contacting Mast Motorsports http://www.mastmotorsports.com I know they were offering a set that were compatible with their harness (CAN gauges).
My friend owns the company that makes the gauge drivers Lingenfelter sells. You could look into those if you want to make something you like work. They did my gauge cluster conversion in the BMW.
