04 2500HD lq4 to an 86' 1/2 ton short bed 4x4.
Old 10-30-2013, 10:25 PM
H-FIELD's Avatar
Default 04 2500HD lq4 to an 86' 1/2 ton short bed 4x4.
no problem swapping the engine and and cooling system or wiring and will build the fuel system. (done a ls swap in a cj7 so I'm familiar) my question is what to do for gauges? I would actually like to use the 04 cluster in the 86 dash but since they are so different i'm wondering what can be done there. I thought about switching the whole 04 dash in as I saw one in a 86 on ebay and didn't look too bad and not to mention then having dual climate control. I do not want Dakota digital. also doing the 04 rear diff and have a 9.25" front differ from a 08 dodge 3/4 ton for the front diff with drivers side drive line. the plan is to put a big single turbo and drag race this thing next summer. any ideas or links would help thanks.
Old 10-31-2013, 03:26 PM
98TA6.0's Avatar
I used all autometer gauges in my stock bezel. Works very well but pretty expensive. You can make the stock gauges work with sender adapters.
Old 10-31-2013, 03:30 PM
H-FIELD's Avatar
Yeah i'm going to see what i can do with the stock gauges from the 04 so its plug and play and the speedo is programmable with efi live. if the HVAC would work I will put the whole 04 dash in and sterring column.
Old 11-01-2013, 01:23 PM
98TA6.0's Avatar
99+ truck dashes are a pretty common upgrade. Only problem is they look a little out of place with the door panels and there is a weird gap on top by the windshield. I liked the simplicity of the 80 dash so I kept it and went Autometer. I'll post pics when I get home. Only thing is the gauges kinda add up. I think I paid ~$600 for all my gauges. All Autometer Pro Comp. damn speedo is the most expensive part. Cable x box will cost around 400 and the stock gauges are a bit crusty anyway so I couldn't justify it.
Old 11-04-2013, 08:52 AM
H-FIELD's Avatar
I have pretty much decided to go with a classic dash and Speedhut gauges. wish i coudl go with the Can bus ones but 04 is too old I guess. I just like that i can customize them and not have to cut up my old dash. i will just save it.
Old 11-04-2013, 09:04 AM
MichaelElsea's Avatar
Ive always been a fan of the autometer electric setups, simple and looks good
Old 11-06-2013, 07:31 AM
98TA6.0's Avatar
If you used the factory th350 or th400 from the truck you could use all your gauges. Sometime I regret not using my original 400 but when I'm going 80 on the freeway at ~2000 rpm I forget all abupout it.
Old 11-06-2013, 11:35 AM
H-FIELD's Avatar
Yeah not going that route lol tried that with my jeep and didnt take long to goto a built 4l60e
Quick Reply: 04 2500HD lq4 to an 86' 1/2 ton short bed 4x4.
