compressor, turbine match
I was wondering if anyone has used the GTX3576R turbos in a twin setup on a LS7. This is a street car only for now. I'm curious about the turbine match. An ar of .63 or .82 for the street. I know there are other factors to consider, gear ratios and such. If someone has had good results with these could you let me know. thanks in advance.
I know a guy here in the UK put a pair of normal GT35's on his 7.0 RX-7, think he said his were in the 1.0A/R range though.
It is making good boost by around 3500rpm
As they typically use the smaller T3 flange, a higher numerical turbine ratio probably makes more sense, especially with the bigger motor.
i was thinking of the Tial stainless turbine housings. they come in a .63, .82, and a 1.03 for that compressor. But those are a V band housing. Have you heard of anyone using those?? i think that's correct, i didn't see a 35 with a T4 only T3's and Vband.
stevieturbo i watched the vid. nice run. i have friends in liverpool and manchester. worked with them in iraq. i like the history over there but not so much the weather LOL. thanks for the help.
