Optima Blue Top
Optima Blue Top
Will i experience any problems running this battery?
ONe uy told me the only problem I might have is the 920 crank amps being too much for the stock wiring.
Ungrounded Moderator
It's amazing what kind of BS some people will spout as facts. The capacity of your battery will have absolutely no effect on your wiring! The battery doesn't push current into the electrical system, the electrical system draws current from the battery as it needs it. Having a higher capacity battery just means that it is capable of delivering current at higher rates (if needed by the system) or for longer periods of time. Your system isn't going to start needing more power just because you have a bigger battery so there will be no effect on your wiring.
Copy & Paste Moderator
I found Optima's site
Starter ("Red Top")
http://www.optimabatteries.com/produ...rter/index.asp
Deep Cycle ("Yellow Top")
http://www.optimabatteries.com/produ...ycle/index.asp
Marine ("Blue Top")
http://www.optimabatteries.com/produ...rine/index.asp
--VIP1
Starter ("Red Top")
Marine ("Blue Top")
--VIP1
The reason I want such a large capacity battery is that I want to be able to run my inverter on for long periods of time without having to turn the car on.
The red-top should be fine for this, but at 50 bucks more, why not get the blue top?
Originally Posted by Cal
Exactly right . . . amazing how some people don't understand this, and worse yet spread the bad information.
