ls swapped vehicles (s10s)
Whats people with basically stock 5.3s swapped runnin in th 1/8 hopefully I can get some s10 input as thats what mine is
Mine 91 s10 single cab short bed no heat or a c, some weight reduction, 05 lm7 1 5/8 headers, vic jr intake, msd 6010, 750 dual feed vaccum secondary holley, accel super coils, no p/s 2300 -2700 rpm stall from jegs, th350 fully manual valve body unknown rear gear cuz the trucks not done
Any guesses on power and 1/8 times. I know it wont be super fast just lookin for a good street truck
Inputs welcome
Ethan
Inputs welcome
Ethan
Its temporary, I plan on big big turbo next winter, prob making my own headers for that, either 1 5/8 or 1 3/4 for that, this is just a budget year to see what stuff I have to change
http://paceperformance.com/i-8378313...p-headers.html
Dirt trackers do this around here, seems to work pretty good
http://www.circletrack.com/enginetec..._your_headers/
I have the same truck as you. same carb, headers, trans without man valve body, 2800 stall, 4:10s welded, 2 1/2 duals to rear axle, with mufflers and then dumped. im running the performer intake. stock 5.3. 160,000 mile junkyard motor. 3000lbs with me in it. Was running 8.38 in the 8th last summer. only got it to the track a couple times so no real tuning. some carb tuning, and better converter and trans, I should be close to 8.00.
Stock for me with brp longtubes. I have a blazer which sits about 1.5 inches higher than the s10's. I just used a heat shield for protection. Starters on these newer engines aren't like the old big sumbitch's on the old SBC engine, lol
Long as it works, people do it all the time. If it doesn't, it will be your 15 or 20 buck core for a new one anyway
On the old setup I had with the mid 80's 305, the starter rubbed the frame on mine, that may be where you saw it on an older swap
