WTB: 3" over axle pipe only.
Don't know if this helps, but Dynomax sells all of their pieces separately through Summit, Jegs, Autoplicity, et al. This is the cat back I have but I pipe curves up on the end so the the over axle piece 53061 ($60) doesn't go like horizontal then over the axle. Not sure what config you need.
http://www.dynomax.com/assets/instru...structions.pdf
