01 ws6 m6 h/c crate ls6
Year: 2001
Make: Pontiac
Model: Trans Am
Price: $11000
Mileage: 1
Private or Dealer Listing: Private Listing
Location (State): KY
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
the car- real 2001 ws6 ram air ttop trans am factory 6spd with 132k on body 15k on engine and trans you would never guess it has that many miles looks like a 60k mile car
engine:
-crate ls6 short block
-p.r.c. stage 2.5 cncd 5.3 heads
-thunder racing custom grind comp cam
-double valve springs
-chromoly pushrods
-ls7 lifters
-ls6 timing chain
-ported and shimmed ls6 oil pump
-ported ls6 intake
-port and polished throttle body
-32 lb injectors
-msd spark plug wires
-nkg gapd spark plugs
-optima red top battery
-professionally tuned
-slp air lid
-slp smooth bellow
-k&n airfilter
-descreened maf
-lower ram air kit
trans:
-tremec crate t56 6spd (3rd gear is messed up)
-hurst short throw shifter
-hurst short stick
-hurst sidewinder ****
-monster stage 3 clutch 5k miles
-tick slave 5k miles
-tick adjustable master cylinder 5k miles
-tick remote bleeder 5k miles
supsension:
-umi tubular k member
-umi trans brace and torque arm relocation bracket
-bmr strut tower brace
-Eibach lowering springs
-founders adj panhard bar rod ends on both ends
-bmr rear lower control arms
-founders rlca relocation brackets
exhaust:
- bbk long tube ceramic coated headers, bbk ypipe, borla cat back
exterior:
-wheels custom dished chrome c5s 18x10.5 rears 17x9.5 fronts
-nitto 555 tires all around
-also have ccw classic drag set up that ill let go for right deal
-blacked out tail lights
-tinted windows
-shaved antenna
-slp iroc spoiler RARE
interior: (tan/ebony)
-leather seats with lumbar came out of my 74k mile ws6 i wrecked swapped a couple weeks ago
-factory monsoon sound
-kicker 10' sub with 600w amp
-triple gauge pillar pod
-aeroforce interceptor smart gauge
-aem wideband afr gauge
-digital oil pressure gauge
-autometer shiftlight
-interior mount antenna
misc:
-aluminum drive shaft
-mirrors under the hood
-slp fan switch
the bad- has the usual sail panel popping 3rd gear of course door panels are cracked (common on these cars) rh head light is grinding. there then that car is near perfect
call or text 270-564-5735 thanks
I have a 99 Sierra rcsb. It has the 5.3 in with a p1 pro charger and a gear vendors over drive unit. just had Jeremy formato tune it a couple weeks ago. also just put brand new 60lb injectors in it. has a nice tonneau cover . its.black with cloth . only has 50k on the truck.
hey i seen your car on craigslist i have a cobra i would trade you if you want you can text me at 2178712004 and i can send you information and pics im not on hear much so i wont respond to replys on hear thanks
