v6 to lt1 swap help!
Old 11-03-2013, 12:09 AM
4thgenbeast's Avatar
Default v6 to lt1 swap help!
I recently bought a 2001 v6 camaro I am currently doing an lt1 swap I was just wondering if I needed a new wiring harness and front springs and what else I would need and I also was wondering if I should go with a twin turbo or a surcharges thanks
Old 11-03-2013, 12:31 PM
the_merv's Avatar
Yea you'd need the Wiring Harness setup for it..the LT1 PCM will not run the Gauges tho.
If you have the money to go boosted you have the money for a LS Swap..put a LS in it.
Old 11-04-2013, 04:06 PM
zrultima's Avatar
LS1 would be the way to go get an iron block 6.0 will be bolt on for you
Quick Reply: v6 to lt1 swap help!
