auto meter speedo& 6l80 trans
Old 11-03-2013, 09:22 PM
hotrods301's Avatar
Smile auto meter speedo& 6l80 trans
hi guys. my first time on this site .just got my first ls swap running .2010 ls3 from a camaro & 6l80 trans from 2008 pont g8 . I have auto meter gauges & my speedo does not respond to signal from the computer . any help would be great THANKS
Old 11-03-2013, 09:34 PM
1989GTA's Avatar
Mine did not work right either and I was splitting off the VSS signal between the 6L80 and the E38 ECM. I am using a Speedhut guage. Speedhut and others now make a speedometer that will read off the GMLAN wires. I just purchased one and will install it in about a month. Car is at the paint shop right now.
Old 11-04-2013, 12:45 AM
Punisher8738's Avatar
Do you think the dakota digital Sgi-5 would work? On my jeep I had a similar issue and used a similar product put out by bluemonkeymotorsports.
Here's a link.
http://www.dakotadigital.com/index.c...rod/prd126.htm
Old 11-12-2013, 10:36 AM
Hart_Rod's Avatar
Try changing the signal to 4cyl, vice 8.
Quick Reply: auto meter speedo& 6l80 trans
