What size of bolt do you use to replace the factory shifter-to-linkage bolt?
I keep reading that you should replace your factory allen head/all thread bolt to a "shouldered" bolt....and I'm going to, but i can't find anywhere online as to what size/length is used to do this!
I'm going to be getting a new shifter very soon, but am doing some other maintenance mods this weekend and would like to try this one out since it's so cheap.
thanks
thanks
i have to drive the car...so I can't exactly pull it or i would, lol
and the stock bolt is fully threaded and eats up the bushings, it's a contributor to what makes CTSV shifters suck so damn bad. It's a very cheap/easy mod to replace the bolt, IF you know the size to get...
I just took calipers to a stock shifter I had laying around and it measures .3305" a standard 5/16" bolt with a shoulder fits very snug... you may need to sand or file some, different bolts have varying tolerances. The shouldered area of the bolt needs to be about 1.25-1.5" long.
PM me if you want more info or pictures.
CTS-V Shifter Sales
The inside diameter of the metal collar is 8.0 mm. I believe people use an 8mm aircraft shoulder bolt that is 50mm long. The shoulder should be about 38mm long.
The only reason people need to change it out is if they have or are worried about stripping the 5mm Allen in the button head.
